Other Parts Discussed in Thread: BQ24195
TPS61235P didn't back to active mode with 100mA
Hi There:
Greeting~ I'd like to need your help to provide some suggestion about our customer who use the TPS61235 & BQ24195 as power bank solution (see attached file schematic)
They now have an problem about TPS61235 mode change from inactive mode to active mode. (see the attached 1.jpg)
detail desription:
1. EN-pin low->High, with a current raise (about 40mA, less than INACT_th), INACT pin enable and turn into inactive mode
2. After about 450ms, with a current (about 100mA, greater than INACT_th), INACT pin didn't disable and turn into active mode
our customer would like to know:
a. why device didn't change the status when the 100mA loading occurs?
b. the INACT_th & INACT whether have the tolerance with threshold current & time?
Thanks again~
B&R
