BQ2002T: Circuit example
Part Number: BQ2002T
I am not sure what exactly I should do with CC pin of BQ2002T? I understand that it is PWM output, but I am not sure if I should connect it to Base of transistor via Integrator and voltage drop will be realized on tranzistor (current source), or connect it directly to base or gate of transistor and PWM will go through the batteries?
Thank you.
