Hi everybody !
I designed a receiving circuit of wireless charging for a li-ion battery 3.7 V 600 mAh. i just need help to verify that my components's values are right and functionnal for my application and that worked well with the coil that i already choose it. And i have some issue:
for the TS/Ctrl, is it right to set the TS with a resistance of 10 K .
i follow the datasheet note, is the value of RFod exact ( 196 ohm) ,R1 ( Reistance limite 66ohm ) , RRos (20)
For the Q24040, i let the NC and EP pins Flotting !!
is this coil concur with this resonnace configuration !!
Thank for your help in advance!
Best regards!
