Hi support team
LM5025 can support both applications to use P channel and N channel as active clamp switch.
In the datasheet and LM5025EVM, The application using P channel FET as active clamp switch only has been shown.
Do you have any application using N channel?
if LM505 use input voltage is 110V solution and I find high voltage P channel mosfet difficult to find
