Hİ team,
I'm trying to generate a 5Volts power supply from 1.2Volts Ni-MH battery by using the Booster TPS61222,
But without load, I have Vout=5Volts when the circuit is loaded (10mA and more) the Vout voltage drops (from 5Volts to less than 4Volts).
I used the circuit as indicated in the datasheet:
This is my PCB layout at below. I checked any connection.
Please could you help me with this issue, I am looking forward to your advice.
Thank you
