Other Parts Discussed in Thread: LM3644, USB2ANY
When we run the Windows C# executable LM3644_GUI_r1.exe the following message is generated "TestApp has stopped working".
Please try the software found in this link below. Please make sure to unzip all of the files into one folder including the embedded zip files as well. Hopefully this should take care of things.
http://www.ti.com/lit/zip/snvc183
Greg
Hi Greg - That works! Thank you. The GUI application runs successfully.
In that zip file, there is a c++ dll file. Where can I find documentation for that? I assume it is an API to control the driver. A sample application would be great.
Thanks again,
Casey
Hi Greg,
We have the LED control through your controller chip using the Future Tech Dev C232HM USB2 to I2C device. Unfortunately it's only a USB2 device but we can control the LEDs on your dev kit board with a C-based API. Very nice. I'll follow up once we start using it at our required frame rates.
Casey
