Other Parts Discussed in Thread: TPS22953
I am planning to use TPS22954 (with QOD) in my design , currently using TPS22953 & planning to replace with TPS22954.
My Bias voltage will drop to 1.5 V from 3.3 V when the enable of the device device goes below the VIL falling threhold. I tested it , the QOD works , the O/P discharges to 0 V within 10 mS & the load cap on the output is 88 uF.
Just like to know until what level of Bias voltage QOD will work good ? Is there any constraints on VIN voltage levels for QOD ?
Vignesh
