Other Parts Discussed in Thread: TPS65217
Hi All,
We are using TPS65217DRSLR for our current project, and in this IC datasheet there are TWO reset register values which gives default output voltage at initial stage before programming.
Now my question is which register setting I will have to take to make sure my default output voltage?
I have attached the datasheet for your reference.tps65217_LDO3pdf.pdf
