I have 8 18650 cells in series, with a BQ76930 monitoring and an NXP micro talking over I2C. The I2C uses CRC.
I have good control of the device, I can read voltages, command balancing etc.
Without sending the command to switch on the DSG FET I see the CC_READY bit being set, and I can clear this, and I have seen under voltages from flat cells so I know the SYS_STAT register is being reported correctly.
When I first command the DSG pin to activate, I see the pin go high then the ALARM line goes high and the DSG pin goes low.
There are no bits set in the SYS_STAT register.
What can cause the ALARM pin to be set when the SYS_STAT register is all zeros? I can't find anything in the datasheet or on this forum.
Mike
PS The ALARM pin has a 510k pull down and it goes to a digital input of the NXP micro, which is configured with no pull-up or pull-downs.
