I have issue with LM25005 design.
My pcb is working only when I removed Rramp resistor.
What is destination of this resistor in webench?
There is no such resistor in datasheet.
Yuriy,
Rramp is discussed on pg 12 of the datasheet. It increases the ramp slope compensation to help reduce sub-harmonic oscillation. This will help high-VOUT, high-duty cycle applications. It is just there to improve operation of the circuit and is not necessary if the circuit works to your specs without it.
-Sam
Sam,
many thanks for you response, I have read the sections about the Ramp and as I understand the resistors using only if output voltage more then 7.5V
Why I should put the resistors for - 6V output in design what I got from the Webench ?
Value for the RAMP resistor what I got is - 6.98 Ohm - using calculation of datasheet the value shouldbe about 280 kOhm, so valuse 6.98 Ohm is correct?
Link for my design here, please advice if the value 6.98 Ohm is correct. Thank you.
webench.ti.com/.../webench5.cgi
Hi, try to use it:
https://webench.ti.com/appinfo/webench/scripts/SDP.cgi?ID=169793770E566AD0
Thank you !
