Just checking - suppose i connect the TPS22922 ON pin to 3.3V, then at some point later set VIN to 1.8V. Note this is kind of the opposite of the sequence in its datasheet. Question is, will the part behave correctly i.e. allow VIN to VOUT, then later if ON is 0V will VIN be disconnected from VOUT.
