TPS65381A-Q1: Quiescent Current
Part Number: TPS65381A-Q1
Below is the standby current. How about the Quiescent Current when all regulator is enabled but no load?
Thanks.
  • Jerry,
    I have forwarded your request to the product specialist to get the detail currents that you need. Thank you for using E2E.
  • Hi Jerry,
    Because the device is so configurable we do not specify a powered but unloaded bias current for the device.  It will depend on if there is IO loading due to pull up and down resistors in the system, how the watchdog and MCU ESM are configured and the configuration of the regulators and if they are enable or disabled.  A typical value for most users would likely be approximately 10-15mA but it will really depend on your specific application and how you have configured the device.
    Please let us know if you have further questions.
    Scott
