The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS63000-Q1: The thermal Information of TPS63000
Part Number: TPS63000-Q1
Other Parts Discussed in Thread: TPS63000
Dear Team,
May I know what's the with Rj-c , Rj-b , Ψj-t parameter of TPS63000-Q1?
It should be different from TPS63000 because the Rj-a are different.
Shaq
  • Hi Shaq,
    The difference is minor. you can use the values from the TPS63000 datasheet, they have been updated recently, it is more accurate.
    We plan to have the same table in the new revision of the TPS63000-Q1 datasheet.
