Dear support team,
Do the Balance time/mAh Cellx parameters need to be scaled, if we're using current scaling? I'd presume that if the capacity parameter is halved, the balancing time/mAh would need to be doubled. But this is hard to confirm by reading the spec, since I'm not sure which parameters the balancing algorithm uses.
BR,
Antti
