Other Parts Discussed in Thread: TPS54527
Hi Team,
my customer uses the TPS54327 and TPS54527 to generate the 3.3V rail in the system.
In the manufacturing process he will power the 3.3V rail from an external source to program the microcontroller while the remaining circuit stays unpowered.
When he is powering up the 3.3V at Vout rail while the Vin is unpowered, there will be current flow over the HS-FET to the Input rail.
What is the reverse current the TPS54327/TPS54527 devices can handle on the HS-FET without being overstressed?
Thanks!
Joe
