Other Parts Discussed in Thread: TPS7A47, TPS7A83A
Hi team,
A customer has some questions about spectral noise density in the datasheet of TPS7A90. Could you please answer the followings?
Can you explain the meaning of spectral noise density?
There are PSRR and spectral noise denisty as parameters that explain the noise characteristics in TPs7A90 datasheet. How do the two parameters differ?
- Is PSRR and spectral noise density independent of each other? In general, if the PSRR is good, does the spectral density have a good performance? Ohterwise, are the parameters independent of each other?
If two LDOs ahve similar PSRR performance and one LDO has poor spectral noise deisty, how does the output noise analyze?
Sam Lee
