TPS61120: LDO Maximum Output Current
Part Number: TPS61120
You can cancel the question I had about the LDO maximum current for the TPS61120. I answered it myself after realizing that the device will only 'boost' one signal and the LDO can either use the boosted output or the battery voltage directly.
  • I don't have the access to delete the question you post. if there is no further technical question about the device. just click the problem resolved. if you still have technical question about TPS61120, build a new post and just describe your question or the issue you met.
