TPS25910: TPS2590 Vs TPS25910
Guru 13485 points
Part Number: TPS25910
Other Parts Discussed in Thread: TPS2590, , TPS2595
Hi
What are the main advantages of the TPS25910 over the TPS2590?
  • Hi Eli,
    Thanks for reaching out!. Let me know your system requirements and use case to suggest most suitable device.
    Both the devices are over-current protectors however there is functional difference in the overload response.
    TPS25910 limits the output current for an over-current event where as TPS2590 device provides circuit breaker function and allows transient overload to the load for fault interval set at CT pin.
    TPS2590 provides selectable latch & retry option whereas TPS25910 is auto-retry device
    TPS25910 provides access to GATE there by provides option for output voltage dvdt control.
    Rakesh
  • Hi
    Thans.
    I just asked fr a quote for TPS2590 and got request to move to TPS25910......
    Are they P2P?
    Both have same package and pin count but not P2P compatible.
    Rakesh
  • use it for GPS power switch and current limit, I've attached schematics
  • Hi Eli,
    Thanks for the schematic. If there is a possibility for schematic change, please look at our newly released part TPS2595.
    TPS2595 offers better current limit performance and is available in 2mm*2mm size
    Rakesh
