Other Parts Discussed in Thread: TINA-TI
Hi
I need to simulate TPS61222 IC in Keysight ADS. I got PSpice Transient Model for this. but its not working. Please help.
Kowshik
Hi
Kowshik
Hi Kawshik,
If you are using ADS for your simulations, please refer to the following FAQs. In summary it would be advisable to simulate the device in either PSpice or TINA-TI.
Hi Kowshik,
For part recommendation, you can enter your specifications in WEBENCH power designer (or search using the parametric search table shown below). You will need to know your current load in order to find a part.
All PSpice models can be found using the link below. Most Boost converters will be encrypted so you will not be able to import them into ADS. There are some older models that are unencrypted. You may be able to import them into ADS, but we can not guarantee that these will work in ADS. If a model is open (unencrypted), you are free to work with Keysight/Agilent to make it work in their simulator (ADS).
Some other useful resources that you may find helpful:
