Other Parts Discussed in Thread: LM4132, REF3425
i would like to use the REF2025 on a project i am currently working on, and i would like to know if it is possible to leave the EN input pin floating. There is no specification about this in the datasheet.
For the LM4132 for example there is the following spec in the datasheet: "The EN pin uses an internal pull-up current source that may be left floating.” It is also the case for the REF2025?
thank you.
Stani
