Other Parts Discussed in Thread: TPS61175, LM3488, TPS55340, TPS61230A
Hello everybody.
I have a project is generating 5V ouptut from Vin change from 2 to 26V, so i used with TPS55065-Q1 buck-boots converter.
But have an issue with startup volatge must above 5.8V in boot mode while startup duration.
So in casing with in put volatge below (2 to below 5.8V) the boot mode cant not run, so circuit will not have power supply.
And I want to help find another solutions in this case, Does TI have another buck-boot IC dont need startup voltage or have startup voltage below 2V?
If not, can have another solutions to solve my issue?
Pls help me solve an issue.
Thank you.
