Hi Support team,
My customer wanted to use LM5050-Q1 Oring controller for battery charger application, the output of oring is connected to a battery and they need to have the reverse polarity protection for the output to prevent the battery terminal is connected wrongly.
Is it okay to move D1 and D3 from input to output to achieve this?
Also, does it need the back-to-back MOSFET to prevent the voltage from the output because the body diode cannot block the negative voltage from output even the MOSFET is OFF.
Thank you.
Wei-Hao
