The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS40075: is there any Output UV, OV features?
Part Number: TPS40075
Hello Team,
My customer intend to use TPS40075, and they intend to change output voltage by changing feed back resistor, the Vout = 1.0V or 1.05V changing level.
now, they are concerning about if TPS40075 has output UV or OV feature? if so, to do Vout change may fault trigger UV or OV.
I don't see UV OV features in datasheet, may I have your confirmation?
Martin
