Hi Sir,
Could you please provide power consumption formula, we have to calculate actual application Pc in our design.
Thanks!
Component PN: TPS22924CYZPR
Hi Sir,
Thanks!
Hi Richard,
I'm not sure what you are asking for here. If you are looking for the amount of power the device is consuming to stay powered on, then you can multiply quiescent current by input voltage. If you want to know the amount of power the device is dissipating from VIN to VOUT, then you can multiply on-resistance by the current squared (P = I^2 x R).
Let me know if this addresses your concerns.
Alek Kaknevicius
Hi Richard,
The caveat here is that the on-resistance will increase with increasing temperature, but this is the way to calculate power dissipation for temperature rise in the device.
Alek Kaknevicius
