Other Parts Discussed in Thread: BQ40Z80, BQ40Z50
HI. Terry / Batt
I further observed the effects of the BMS Chip and Charger mode and DSG Gate waveforms, and found that the Chrager action has absolute influence.
I tried several modes of testing. (See the attached file charger modetest results),Whether the Gate uses a Diode or a resistor, this voltage will be affected as the Charger is turned on or off.
These tests may be helpful in analyzing the problem, and attaching the PCB layout of this Project, can you provide suggestions?
Janson
