Part Number: BQ24010
Other Parts Discussed in Thread: BQ24076, BQ24040, BQ24100
Hi, I want to use BQ24010 for my design. From the application circuit, it is noted that the Charge current output (Pin) is connected to both Battery and Load together, where as in some other battery chargers (bq24076), battery connection point and system supply output pins are different. So, if the charge current ouput is connected to both battery and output load together, how does the charging works, especially in the constant current charging mode where the load current can vary?
