Other Parts Discussed in Thread: TPS61027,
Hi
I will like to use TPS61027 with output regulated at 5V. However I could not purchase the EVB for evaluation purpose.
Instead I could only purchase TPS61020 EVB. As such I will adjust the output to 5V. However the specification didn't
mentioned the following for TPS61020 at output 5V (Efficiency vs Output Current, Efficiency vs Input Voltage).
Can I use the graph data of TPS61027 since they are from the same family?
Kindly advice.
Thank you
