I am looking at the bq24072T li+ charger for my application. It seems to have all the standard safety features for Li+ except over-discharge protection. I do not see anything in the datasheet the indicates the part will disconnect the load from the battery once the voltage has dropped below Li+ thresholds (usually around 2.8V). Is this not included? What other solutions do you have that would incorporate this? Also, what is the benefit to the Power-Path as opposed to the load being connected directly to the battery as is on the bqTinyII series - they still seem to operate in the same fashion.
