Hi, Team
My customer is using TPS65175. They find the rising edge of EVEN (pin 46) is 1.8s delay from VST (pin 45) signal. They need rising edge of EVEN comes 10ms earlier than VST signal. Could you advice how to modify the sequence?
Here is the TPS65175 waveform.
CH2: EVEN
CH3: VST
Here is the timing requriement from the LCD panel:
Here is the datasheet of the LCD panel:
Kevin
