Hi, my design with TPS7A45 is as following.
But when Pin1 is LOW to disable TPS7A45, the output is around -0.5V. I also tried to put 500 Ohm at pin4 to provide load, but doesn't make any improvement.
How to prevent negative output when TPS7A45 is disabled?
Thank you.
