TPS54202HEVM-716: Output capacitor voltage rating specifications?
Part Number: TPS54202HEVM-716
I am basically copying the evaluation board design into my application. Unfortunately the BOM is not entirely available in my time frame.
I believe I understand how to perform the calculations in the datasheet for the stand alone device. (Data sheet is SLVSDG7)
What I never came across in those calculations was a reason that the output capacitors were rated for 25V when the output was set for 5V.
The real question: Is there a problem with replacing 2 X 22uF/25V/X7R/10% with 2 X 22uF/10V/X7R/10% as the output capacitors?
