I saw a comment in the part datasheet that this products should not be used (or not recommended) for aerospace projects.
Why is that? waht are the problems which you encountered with it in these kind of projects?
Thank you for your help.
Hi Eyal,
Can you point me to the specific section in the datasheet that says this device should not be used? If you are taking about the footnote(2) in Section 6.1 Maximum Rating this statement implies that device has not been tested for Military Grade specifications. However, if you do not require this level of compliance in your system then using this part should not be a problem.
Jimmy
