I use a TPS7A90 IC to generate 5V from 5.25V. I did the schematics according to the datasheet. I soldered the circuit on the PCB, but instead of having 5V the output voltage is the same as the input voltage. I changed the IC, I modified the input voltage, but the result is the same.
Do you have any suggestions, what is the reason for this and how can I solve it?
Here is my schematics:
