LM26001: output voltage transient
Part Number: LM26001
We have designed in a LM26001. It supplies 5 volts at about 50mA, from a 24 volt power supply. It works most of the time flawlessly, but if power is removed for a short duration, I'm getting a voltage transient that peaks at 23 volts and doesn't return to 5 volts for 40 mS. It seems to occur if the power is applied as the 5 volt line drops to about 4 volts. I have already burned up 3 CPU's. Please let me know what I should try next.
thanks
tom
