Other Parts Discussed in Thread: BQ25121A, TPS62800, TPS62740
Hi All expert :
Currently BQ25120A sys pin output default is 1.8V when charger wake up.
Is it possible to set up sys output pin is 3.3V when charger wake up ? any method from HW ?
Dustin,
Best option would be to use a separate DCDC like the TPS62800 or TPS62740 from PMID.
You can use the LS/LDO but note that it will be in load switch mode by default.
regards,
gautham
