Other Parts Discussed in Thread: TPS7A30-49EVM-567,
Could you confirm the correct configuration with the sense line. It appears that the sense line should make contact with the regulated output at the point where the circuit being powered (power entry point) is located. Can you confirm this please.
Also where would the best location be for the capacitor referred to as CFF 10nF.
I ask this because your evaluation board ties the sense line to the output voltage, on the actual board, rather than offering a V out / GND out and Sense out. Presumably this is just for convenience and is not the best way to configure the device.
