Hi expert,
My customer used TPS61185 for their panel backlight application.
They found out there is inrush current at 5Vin. We would like to know if it is normal operation when we used direct PWM dimming which is switching from 0A to Iset. And also we would like to know if LED current will drop to zero when PWM is keep high. As we know, it should keep Isat when PWM is high. Would you please help on it? Thanks a lot!
CH1:Vout(34V), CH2: direct PWM signal, CH3: LED negative side, CH4: total output current from Boost stage.
Ann Lien
