Dear TI Experts,
My customer have a PP project with BQ27545, there is a SDA test point which is very close to B+, and this may cause short sometimes. They use HDQ to communicate, so they don't care the if I2C will be unable to work. They have shorted SDA and B+ deliberately and implemented many trials, like working high/low temperature , several charging/discharging cycles, quiescent current monitoring, and all other function test, and everything work well so far. Could you kindly give some advices about this case, is it safe to keep the current design? I'll appreciate it if you can share more info about chip's internal circuit about SDA,and give a suggestion if this short will be a potential risk or not. Thanks a lot.
