Part Number: TPS2121
Hi Arthur.
I have one additional question about other case.
If the supply1 is positive voltage and other supply is negative voltage connected, will the device break ?
In our case, It will be connect a battery and the other side sometimes may be connect the reverse connected power supply.
My understanding is the current will flow through the internal diode when negative voltage is applied.
So , current due to negative voltage does not flow inside the device.
Sincerely.
Kengo.
