Hi team,
The customer wants to measure frequency response with FRA for DCDCx. But, when the output voltage is set by default, no requires feedback resistor divider outside of IC. For that case, how to measure the frequency response with FRA? FRA manual describes proving is close to the feedback resistor, but nothing of the outside of IC. Or if you can disclose some functional block diagram, it helps the customer design. Thank you for your support.
Takeshi Sasaki
