Hi , in one of the project I am using LMZ10503 where output voltage we require is 3.3 volt. But I want to know the input voltage range to get the output voltage of 3.3 volt. Pls reply as soon as possible. It's urgent. please also explain what is the maximum and minimum voltage is required to get output voltage of 3.3 volt.In datasheet in general range is defined from 2.95 to 5.5 volt for input voltage but I want exact data for 3.3volt output voltage.
Kirti Azad
Bangalore
