I am considering using UCC2897A device.
If you do not use the SYNC pin, it is recommended to open this pin in the data sheet. The reason is that this pin is bi-directional.
However, when considering noise such as lightning surge and static electricity, I think that fixing this pin is safe.
Since there is no description of whether to pull up or pull down in the internal block diagram, I would like to know the internal configuration of this pin.
Fixing to H is prohibited in the data sheet.
Is it possible to fix to L?
