Further to the discussion of TPS3600D33PWR, I have a couple of questions as follows:
- In page 9 of datasheets, at watchdog section, it states "If the input is unconnected the watchdog is disabled and will be retriggered internally." . Can you elaborate this statement? Does it mean the user has to use this watchdog function, otherwise the chip will consume more current? What does "retriggered internally" mean anyway?
- Is the output /RESET pin open drain or push-pull? If it's a push-pull, should I use a diode when I connect to a open drain Reset in micro-controller?
Thanks.
