I am using LMV431BIMF/NOPB in series pass regulator for 2.5V output. Found that initial reference tolerance is not meeting the values defined in spec. The measured reference voltage was less than the lower spec. of the temperature range. However when I test the same part configured as shown in test circuit 32 of the datasheet meets the defined spec. Appreciate if someone explains why this difference and how to resolve this issue.
