Hi TI team
Is it possible UCC28950 to make 12VDC(Battery) to 400VDC POUT 200W?
Best regards
Watchaphong
Hi TI team
Best regards
Watchaphong
Hello Watchaphong
It's possible but it would make no sense because the Phase Shift Full Bridge is too complex for this power level and its Zero Voltage Switching feature has no advantage at 12Vin and these low power levels.
A better solution would be to look at a push-pull power stage - possibly the LM5036 would be a suitable choice. You can see the full selection of TI push-pull controllers by going to http://www.ti.com/power-management/offline-isolated-dcdc-controllers-converters/pwm-resonant-controllers/products.html#p1129=Push-Pull
Colin
Hi Colin
Thank you for your suggestion. and i have more question.
1. The peak power is 600W. it's possible to use push-pull?
2. Minimum power for PSFB suggestion?
Watchaphong
