Part Number: TPS2561
Other Parts Discussed in Thread: TUSB8041
Hi team
I designed the TUSB8041 circuit same an application circuit.
In the application circuit, the EN pin of the TPS2561 is connected to the PWRCTRL1_BATEN1 of the TUSB8041.
Currently, It was direct connect between EN pin of the TPS2561 and PWRCTRL1_BATEN1 of the TUSB8041.
I will disconnect pin to pin.
And, I want to design that it always is pull-up EN pin of TPS2561.
If the TPS2561's EN pin design pull-up, could this cause problems with the USB system?
