Hi all.
<Question>
①Can I use the separate power supply without using SW / FB pin?
If it is okay to use a separate power supply, can the SW / FB pin be left unconnected?
②I use manual mode.When using the manual mode, is it not necessary to use the VLDO / S1-IN / S2-IN pin?
If it is not necessary to use it, is the connection of VLDO / S1-IN / S2-IN pin as shown in the figure and correct?
I look forward to hearing from you.
Syunpei Koshima
