UCD9240: Programming SVF file using 3rd party JTAG adapter
Part Number: UCD9240
I am trying to re-program a UCD9240 part on my board using the SVF file exported from "Ti Fusion Power Designer" software.
Unfortunately I dont have access to Ti USB-to-GPIO adapter, Nor to any of the JTAG adapter recommended by Ti in the document entitled: "Configuration Programming of UCD Devices".
So for, I've managed to prepare the basic setup required to download svf file to the device:
- The address Pin of PMbus are shorted to ground to enable JTAG interface.
- The JTAG adapter (digilent jtag-hs2) is connected to JTAG interface of the UCD9240 and power is applied to the board.
- OpenOCD is used to program SVF file into device and this command is invoked to programm the UCD9240:
openocd -f digilent-hs2.cfg -c init -c "svf /home/mahmoud/Desktop/UCD9240.svf"
After that, the OpenOCD begins to write the SVF file into device, But After a while, It stops with the following error:
Error: tdo check error at line 114
Error: read = 0x20B8E, want = 0x38458554, mask = 0xFFFFFFFE
(The complete log file is attached).
Any help is appreciated.
ucdlog.txt
Open On-Chip Debugger 0.7.0 (2013-10-22-08:31)
Licensed under GNU GPL v2
For bug reports, read
	http://openocd.sourceforge.net/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
adapter speed: 1000 kHz
none separate
Info : clock speed 1000 kHz
Warn : There are no enabled taps.  AUTO PROBING MIGHT NOT WORK!!
Warn : AUTO auto0.tap - use "jtag newtap auto0 tap -expected-id 0x4f1f0f0f ..."
Warn : AUTO auto0.tap - use "... -irlen 4"
Warn : gdb services need one or more targets defined
svf processing file: "/home/mahmoud/Desktop/UCD9240.svf"
ENDIR IRPAUSE;
ENDDR DRPAUSE;
TRST OFF;
STATE IDLE;
SIR 4 TDI(2) SMASK(F) TDO(1) MASK(F);
SDR 4 TDI(2) SMASK(F) TDO(0) MASK(0);
RUNTEST IDLE 1 TCK ENDSTATE IRPAUSE;
SIR 4 TDI(C)  TDO(1) ;
SDR 38 TDI(0100000000) SMASK(3FFFFFFFFF) TDO(0000000000) MASK(0000000000);
RUNTEST IDLE 1 TCK ENDSTATE DRPAUSE;
SDR 38 TDI(2000000002)  TDO(0000000000) ;
SDR 38 TDI(0100000000)  TDO(0000000000) ;
SDR 38 TDI(2000000005)  TDO(0000000009) MASK(000000000F);
SIR 4 TDI(2)  TDO(1) ;
SDR 4 TDI(1) SMASK(F) TDO(0) MASK(0);
SDR 33 TDI(03DC43DC4) SMASK(1FFFFFFFF) TDO(000000000) MASK(000000000);
SDR 33 TDI(006C406C4)  TDO(000000000) ;
SDR 33 TDI(000000B0E)  TDO(000000000) ;
SDR 33 TDI(000020B8E)  TDO(000000000) ;
SDR 33 TDI(00010334E)  TDO(000000000) ;
RUNTEST IDLE 2 TCK ENDSTATE DRPAUSE;
SDR 33 TDI(035FC0000)  TDO(000000000) ;
SDR 33 TDI(000000B0F)  TDO(000000000) ;
SDR 33 TDI(00001134E)  TDO(000000000) ;
SIR 4 TDI(4)  TDO(1) ;
RUNTEST IRPAUSE 25E-6 SEC ENDSTATE IRPAUSE;
SDR 33 TDI(000020B8E) SMASK(1FFFFFFFF) TDO(000000000) MASK(000000000);
SDR 33 TDI(00000234E)  TDO(000000000) ;
SDR 33 TDI(000000B0E)  TDO(138458554) MASK(1FFFFFFFE);
SDR 33 TDI(000020B8E)  TDO(000000000) MASK(000000000);
SDR 33 TDI(075FC0000)  TDO(000000000) ;
SDR 33 TDI(000000B0E)  TDO(168185898) MASK(1FFFFFFFE);
SDR 33 TDI(00DFC0000)  TDO(000000000) ;
SDR 33 TDI(000000B0E)  TDO(1987C1838) MASK(1FFFFFFFE);
SDR 33 TDI(04DFC0000)  TDO(000000000) ;
SDR 33 TDI(000000B0E)  TDO(0E85898E8) MASK(1FFFFFFFE);
SDR 33 TDI(02DFC0000)  TDO(000000000) ;
SDR 33 TDI(000000B0E)  TDO(11838E818) MASK(1FFFFFFFE);
SDR 33 TDI(06DFC0000)  TDO(000000000) ;
SDR 33 TDI(000000B0E)  TDO(0187D98D8) MASK(1FFFFFFFE);
SDR 33 TDI(01DFC0000)  TDO(000000000) ;
SDR 33 TDI(000000B0E)  TDO(119381838) MASK(1FFFFFFFE);
SDR 33 TDI(05DFC0000)  TDO(000000000) ;
SDR 33 TDI(000000B0E)  TDO(000000158) MASK(0000001FE);
SDR 33 TDI(00000334E)  TDO(000000000) ;
SDR 33 TDI(04CFFFFFE)  TDO(000000000) ;
SDR 33 TDI(001000000)  TDO(000000000) ;
SDR 33 TDI(00010034E)  TDO(000000000) ;
RUNTEST IRPAUSE 1 SEC ENDSTATE IRPAUSE;
SDR 33 TDI(000230000)  TDO(000000000) ;
SDR 33 TDI(1FFFFFFFE)  TDO(000000000) ;
SDR 33 TDI(040230000)  TDO(000000000) ;
SDR 33 TDI(020230000)  TDO(000000000) ;
SDR 33 TDI(060230000)  TDO(000000000) ;
SDR 33 TDI(010230000)  TDO(000000000) ;
SDR 33 TDI(050230000)  TDO(000000000) ;
SDR 33 TDI(030230000)  TDO(000000000) ;
SDR 33 TDI(070230000)  TDO(000000000) ;
SDR 33 TDI(008230000)  TDO(000000000) ;
SDR 33 TDI(048230000)  TDO(000000000) ;
SDR 33 TDI(028230000)  TDO(000000000) ;
SDR 33 TDI(068230000)  TDO(000000000) ;
SDR 33 TDI(018230000)  TDO(000000000) ;
SDR 33 TDI(058230000)  TDO(000000000) ;
SDR 33 TDI(038230000)  TDO(000000000) ;
SDR 33 TDI(078230000)  TDO(000000000) ;
SDR 33 TDI(004230000)  TDO(000000000) ;
SDR 33 TDI(044230000)  TDO(000000000) ;
SDR 33 TDI(024230000)  TDO(000000000) ;
SDR 33 TDI(064230000)  TDO(000000000) ;
SDR 33 TDI(014230000)  TDO(000000000) ;
Error: fail to run command at line 1367
Time used: 0m1s274ms
svf file programmed failed
in procedure 'svf'
