I need a boost converter for up converting 2.9v or 3.3v to +3.5v and -3.5v. I found in TI web-site the TPS61071 Boost converter.
In the beginning of its Datasheet it says that in its typical application it converts only to positive output.
However, I looked over the datasheet and found that it has another application connectivity which was called "Power supply solution with auxilliary negative output voltage" as in the figure above.
I would like to understand, since it wasn't explained clearly in the datasheet, what is that mean ?
Does it mean this device can output positive and negative voltages in the same time from the VOUT (positive) and SW (negative) pins ? If it does than what is the supplied current on each power pin in such a case ?
Ohad F - Philips
