Other Parts Discussed in Thread: TPS23757,
Hi Sir,
In TPS23757 EVM schematic and datasheet, it shows there has gate1 for main NMOS switch and gate2 for senconary NMOS switch topology.
From datahseet, it shows gate1 and gate2 operation as below information.
GATE’s phase turns the main switch on when it transitions high, and OFF when it transitions low. GAT2’s phase
turns the second switch OFF when it transitions high, and on when it transitions low. Both switches should be
OFF when GAT2 is high and GATE is low.
Many topologies that use secondary-side synchronous rectifiers also use N-Channel MOSFETs driven through a gate-drive transformer.
The proper signal phase for these rectifiers may be achieved by inverting the phasing of the secondary winding
(swapping the leads).
So, please help to provide secondary-side synchronous rectifiers circuit design application note. Then we can understand and verify that
thanks
